power Steering kit/front end loader
I have a 660 with a front end loader and I want to get a power steering kit for it, but suppliers say not to be used with front end loaders. What am I to do?
As you're already aware the kits are big bucks - May check availability for OEM power steering components from the tractor parter outers.
Likely not what you want to hear but unless you stumble across a good deal, you will likely be money ahead to sell you tractor and buy one already equipped with power steering.
You could take about an 1-1/2" off the Pitman arms or install a larger diameter steering wheel.
Also, you would be surprised what 800lbs on the lift arms will do to lighten the front end.
I understand the logic of making the pitman arms shorter, but that's kind of hard to do, isn't it? You'd also loose some turning radius doing that. Also, installing a larger diameter steering wheel is going to take its toll pretty quickly on a manual box.
The others have given you good options. I put the Jackson Power Steering unit on my tractor and it works great. I have a Davis loader. I must add though, that after rebuilding my tractor I wish I had gone with an original unit. Not that the Jackson unit is inferior. It works great. It runs off the loader pump which means that no steering if I take the loader off. There is the option of using a Chevy power steering pump instead, which I am considering. I also understand an early Mustang pump will work too. I keep mu eye out for an original power steering unit. Cost is probably going to be more than the Jackson unit.
There is also and option of installing a torque generator if you have the room. Contact Roland Jackson and he can make a good recommendation for your application. He is one of the most likeable and helpful men you"d ever want to meet. You can find his site on the Web. Google Jackson Power Steering. Hope this helps.
(quoted from post at 14:21:40 08/30/13)Likely not what you want to hear but unless you stumble across a good deal, you will likely be money ahead to sell you tractor and buy one already equipped with power steering.
Sad, but true. I lucked out and found a used PS unit cheap.
Otherwise it would have cost more than the tractor is worth.
I still had to fab all the brackets, idler pulley etc to make it work.
I appreciate all that you all have written. The real problem is I hate taking the loader on and off. I have a 7 acre field that has to be mowed every spring and there are wet spots. I think I may go with weights on the rear and try to set up a better way to remove the bucket in the spring and put it back on in the fall. Any one have a system to make removal any easier?
Thanks all,
Terry
There were several loaders used, so giving you a "system" for removal would be difficult without knowing what kind you have.
Terry, I often joke about buying one tractor for each implement.
But all joking aside, if you're using an older tractor with a loader,
like I do, you may want to consider another older tractor to do the mowing.
Another tractor could be had, in many cases, cheaper than the power
steering and it would save the front end of your loader tractor from
all the added mileage and stress of doing the mowing.
Not to mention your time and labor taking the loader on and off.
My loader arms come off with 4 pins and two quick disconnect hoses,
but I never take it off because there's not an easy way to support it.
It's just another idea but honestly I wouldn't try to run my tractor
around the field mowing with a loader hanging off the front.
Not a good idea even on a brand new one.
I couldn't run my tractor around my field with the loader attached. I have already gotten it stuck in a soft spot with the loader on. I'll have to check the make. It bolts on the front with three bolts and on the back axles with two long bolts. Everything is consolidated in the loader.The fluid is in the tubes of the loader.
Thanks,
Terry
