Power steering leak
Chumbleweed
I got my Ford 2810 out to do food plots this weekend. About half way through fluid started coming out of the shaft leading up to the steering wheel. Does anyone have an idea of what seal may hace given up and were its located?[/list]
I thought I had replied to your post this
morning but must not have followed through
with it.
I looked your steering box up on CNH and it
is the new style like a 3910 so I have not
been into one of those before. But looking
at the diagrams it does have that upper tube
that bolts to the main part of the steering
column. If I were you I would pull that
upper tube and look for a seal. Bet you'll
find one in the bottom of it and bet that's
where it's leaking. You will have to pull
the center hood, steering wheel, throttle
and rear cowel to get at the column. But
that's not too bad of a job.
Thanks for the reply, doesn't sound to tuff to get into.
(quoted from post at 12:56:57 04/11/17) I thought I had replied to your post this
with it.
Well I took the shaft out and there's a seal at the bottom under a large washer. Does anyone know if there are any additional seals under the one I can see? I've looked online and I can only find the one seal. Would be helpful to have a breakdown of the steering column and box but I don't have one.
