power steering on j/d tractor
how do you bleed the air out of the steering on an older 4020 propane fueled . the bottom seal is leaking on the steering motor and the wheels are turned all the way to the left. but will not turn to right .
plus i cant find the tag for the serial number . on the tractor
any help would be apreciated
Normally one can cycle steering wheel from left to right & vice verse to bleed air from steering. There's also a bleed screw(key 6) on steering valve. Sounds as if you need to reseal the steering motor.
