Power steering problems with MF 30E
marwes
I have a MF 30E Tractor/Loader/Backhoe. It has the powershuttle. I had some work on it and when it returned the power steering won't work. The transmission/power steering fluid was a hair below minimal so I topped it off. It is still not working. Everything else works fine. The wheels won't move at all.
Clean screen before
Pump
If neither is working make
Sure orings and seals on can not smashed out also check your hoses they get old and crack
I've checked all those. I'm going to check the steering wheel box next. It seems to be blocking the circulation through there.
Does the steering wheel spin or is it hard
Spinning means you have a bad cylinder packing
Hard means it's in valve or no oil supply
When you lift front end off ground does it move
Are spindles taking grease
What work was done at shop
You said you had some work done on it, so are you saying they gave it back to you in that condition with the steering column froze? How did they move it?
Thank you. I'll take those off next. Can you access the steering box there or see the valve after removing them?
It was on a flatbed. The rewired it on their premise where it was towed then when they got it running and the loader, forward and reverse was working, they returned it.
I took the 4 bolts off of the bottom of the steering column and it just had spindles to connect below. I didn't see anything other than that.
Will the steering wheel turn when the engine is off? It may be very stiff, but will it turn then? If so and any of the hoses were removed, then two or more were reconnected on the wrong port.
