Well, tore into the steering gear and aligned the sector gears. Fortunately I found no broken teeth. For those interested the mid or straight forward position is when the large tooth of the left sector gear is at the top and its fourth groove is aligned with the fourth tooth of the right sector gear. Both have punch marks to help alignment. As Soundguy said, the pitman arms are slightly toward the rear.
Put the cylinders on and adjusted and took the tractor for a spin, first time its moved under its own power since the project began. I have a few more things to do before completion. I'll post a photo of the progress. Thanks again to all to have helped.
