Can the power steering pump seals be replaced while the pump is on the tractor? It looks like the the radiator will need to come off. OHHHHH BOY. The pump looks to be leaking out of the front seal. The power steering works good except for this leak and wheel wobble which I hope I can fix by flipping the gear. If not is this gear still available?
So, after more research, I have found that the old seal part numbers have been replaced by new part numbers and parts. What I am finding is that the new seals take 2 instead of 1 and a spacer in between them. What I am not finding is, how these parts are installed. To me the lip of the seal goes towards the oil. Will both seals be installed this way with the spacer in the middle? Will I have to disassemble the pump to replace the seals?
