power steering
Rancher Tim
I am installing power steering from a 800 to a 600 never saw how it was mounted on the 800 but could use some help installing on the 600 like where does the pump get mounted anybody have pictures or a web site or any knowledge would be greatly appreciated.
should be a pictoral in the manual in the service section.
in any case, the pump mounts at the top right front of the engine. hope you got the top radiator hose/thermostat cover tube as well, as it has a bracket eye that is needed.
soundguy
I am in the middle of doing the same thing. Send me an email and I will give you my phone number. I have a lot of the little stuff that you might need and we might be able to help each other. Do you have the reservoir on top or behind the pump?
Like soundguy says, there are pictures in the manual. It takes a power steering water neck, a bracket, bolt and then a turnbuckle to mount the pump. Let me know if I can help.
Jason
probably best to find one to look at like a tractor show or such and take a ton of pictures or I am sure someone here has pics if not I am fixing to tear into 2 of them in a couple of weeks I can send a lot of pics at that point or just some easy outside pics sooner if you need them
