POWER TAKE OFF CLUCH {old}
JR.Frye
HEY OLD
In a post you and I talking about a power take
off cluch for my wd45 when I use my bush hog.
Did or Did you Not say the power take off cluch
should be a slip cluch. So I would not tair out
power take off, and all so I have been told that
I can buy a thing call'd a cylender lock is that right. YOUR THOUGHTS:
JR.FRYE
wd 45 has pto shear pin use grade 2 bolt on ritaty mower or even softer pin to save pto gears Pin is under tractor where pto gear box joins shaft to rear
You need to have an ORC (over running clutch)) So when you push down the foot pedal clutch it will not push you another 10-15 feet and get you in trouble. Ya if you use the hand clutch that will be ok but I know how it gets when you get in a tight place you forget about the hand clutch and push the foot one down and then the brush hog pushes you into that ditch or tree or fence etc.
Would be doing ok if the but heads on here would stop giving me such a hard time but guess I could also hope to win the lottery also LOL. Just had some one else that only knows me from what I say here give me $hit today
