power trol valve
fatyak
I remember reading a caption under a pic that a member had sent in green magazine and they talked about installing a "bypass" valve in the power trol system. This valve allowed the rockshaft and scv valve to be operated at the same time for applications such as a semi-mount plow. Does anybody know what the part number is or if its still available?
Field Service Bulletin 222 described and illustrated how to cut in to the pressure and return hard lines to install the "Cessna" brand valve that came with the 821/822/882/883 roll over plows for the 800 hitch. Today, any open center valve could be installed to operate a remote, while leaving the Powr-Trol "by-the-seat" lever to operate the rockshaft, if you break into the hard lines.
Another way to do it is to install a "Baker" valve, no longer in production, but often obtainable on eBay. This adds a separate fluid port for an external cylinder.
