Power washer
bfullmer
Have a stihl re 100 pressure washer and tip is a twist on plastic piece anyone made an adapter to put pipe thread on to use with normal tips
Probably have the best luck at a power washer shop. The wand tips should be matched to the pressure/flow of the pump.
You might try tips from another manufacturer. I bought a Sunjoe pressure washer and the pump exploded. I replaced it with a Harbor Freight power washer and the parts from the Sunjoe work on the HF washer.
