HAPPY A
JUST GOT A POWERBLOCK PULLED HEAD DOES NOT LOOK GOOD BLOCK HAS A 6 STAMPED ON IT WHAT IS BEST TO MAKE GOOD PULLER
What type of class do you want to run? Cut or uncut tires, what speed limit, etc. That will determine what you want to do to the engine.
You say it doesnt look good, is the engine stuck? If its stuck, take the block out and press the pistons toward the head surface first to break them loose. DO NOT press toward them back until the pistons move free. If you do, there is a good chance the piston is stuck to the sleeve better than the sleeve is stuck in the block, and you will push the sleeve out...not a good thing.
Where you saw the "6" on the block, there should be a dash and then another number next to it, 1, 2 or 3. Which is it?
Happy A,
The 6-2 means that it will fit a 1948-1949 JD A with a "ball shift" transmission that has a High and Low lever and a battery box seat.
If it is pitted you can bore it out to 6.125" and use JD G pistons, extremetractorparts pistons, or curtis aircraft pistons.
