mike199032
Hello everyone,
I am back to working on my tractor after it has sat for several years. (5+) The govenor ring failed and the pump got taken apart. and it sat like that until last week. I ordered a seal kit, put it back together and the tractor will not run. If i hit it with some ether, with will attempt to idle but at full throttle. and slowly die.
During this i have done the following,
Ensure proper fuel flow from tank.
Disconnect the fuel return back to tank. To ensure no clog in the return line.
Metering valve is not stuck and moves freely.
Pump model: DBGVCC 429-14AJ
I do have the pump set to CC direction on the top of the pump along with the timing adjustment with in the pump for the pistons.
I did download and follow the exploaded diagrams of this pump. but to no avail, can i get this tractor to run today. Read several forums here about the pumps and different items to look at.
I am looking for opinions before i take the bullet and pay $1000 for a rebuild locally.
From what i can tell, the low pressure is working, but the high pressure is not. I have not changed any settings as far as i know. Other than when it was taken apart by my self, and then put back together. I did have all parts in a box, and used all parts putting it back together.
Thank you all
-Mike
Thank you all
-Mike
