Powertrol Questions
OK, I just want to check to make sure I am not missing something obvious. With the "dummy plugs" in, the rockshaft moves up and down. Can you leave plugs in that have a quick coupler if nothing is attached and still get use out of the rockshaft? My A, with dummys in it will move, but it keeps pushing the plugs out even with pins seated properly and latch locked up or down. My plugs with quick connects have always stayed in and was wondering if I can just leave them in and not worry about it.
If I remember right, there should be a slotted bolt with a locknut on the powertrol case somewhere. It needs to be screwed either in or out depending on which function you want to use. Can't use both at the same time. That is how I remember it.
