okay guys I am trying figure something out. I asked a question a couple days ago about hooking up couplers. I have dummy plugs now. someone said I could plumb into the side of the box. will I still get the same result.
My understanding is that you'll get the same result minus the oil spillage from taking plugs in and out. There have been several discussion about this on the forum. See, for example, http://search.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=jd&th=465952
...or just use the search feature at the top of the discussion forum. Hope this helps.
Brian that was me that posted a picture on how I've got my power-trol plumbed in to run a remote cylinder. My rock shaft still move a little but that's ok with me. Here's the picture again. 3/4 to 1/2 pipe bushings into the side then a 1/2 to 3/4 street L then a 1/2 pipe nipple then your pioneer fittings.
So... on your 70 does the rockshaft still work when you want it to if the hyd. remotes are plugged in this way?
Is it possible to use the remote when you want and the rockshaft when you want, or do they work in sequence with the lowest load going first.
Say on a three point log splitter. Does the cylinder go in and out without the 3 pt going up and down each stroke? Can you lift the splitter without the cylinder moving?
I have one I want to set up and the option in the picture is way cheaper than buying the correct JD remotes.
my father in law didn't know how it would work he had never done one that way. he always changed out the box. you don't have any issues raising or lowering an implement.
Here's <a href="http://search.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=jd&th=465952">a link to the discussion</a> about 70 hydraulic couplers that [b:654c4848f0]Roger N.[/b:654c4848f0] mentioned below.
Hope this helps.
