So I want to put hydraulics on my b 46 I know I need the power trol but was wondering if there is a certain one I have to get and if I need any other parts to make it work
Does your tractor have a power lift currently?? If so, you need to swap the power lift box for a power trol box. You will need the studs from a power trol unit as well, as one or two of them is a different length.
If the tractor currently has a flat back, you will need the whole rear cover from a power trol equipped tractor.
The valve box from a B, A, G, or 50, 60, or 70 should fit in place of a power lift box.
Yes, then you have some work to do. You will need an appropriate back for a B, and then a valve. You MIGHT consider a back from a later B that has mounts for the square seat???? You will have to see what you can find.
