pressed steel on JD
dallasd
ive never messed with pressed steel before, but i have a JD 730 diesel i would like to put 18.4 34 on.
what kind of hubs do i need and will any 9 bolt rims work.thanks in advance
A set of M&W u bolt hubs for a 4010 should work, I believe your axle diameter is 3 1/8" if so find a set of those. If its a dedicated pulling tractor you can buy weld on hubs to weld to the axle for about $200.
