Pressure plate ? Oliver 77 puller
showdown
At the end of the pulling season last yr. I have a lot of rattling in my drive line. Took it apart found I had to replace my input shaft from flywheel, coupler, and tans. Input shaft. Pulled for the first time and my clutch slipped. My disc looed great when I had it apart earlier. I assume my presser plate is weak. This pressure plate is a least 10 years old. What should I replace it with? Thanks for any help. This tractor pulls in enhanced class.
if you are under 100 horse a super 88 11 in , plate and disk will hold it, need to drill flywheel to accept bigger bolt pattern our get a super 77 ,88 flywheel
