Pressure washer replacement pump
Bob - MI
I have a 6.75hp B&S 2800psi 2.5gpm pressure washer with an AR SJP pump on it and it won't develop pressure. I replaced the unloader valve and it was ok for a while and then just cut the power more than half. I have the EZ start pump that has the spring and ball that stick sometimes so I have replaced that now as well. Same result and I am now thinking about getting a new pump rather than spend more time and money on this.
Any suggestions? New pump brand?
Hello Bob-MI,
Pumps are available through many sources.
One source is devilbiss.
Just do a search Devilbiss pressure pumps, and it will come up for you.
Guido.
I replaced a pump on a 6.5 hp briggs and by the time I got done it was within a $100 of buying a new pressure washer. Just doesn't seem right that pumps are so expensive.
Next time, I'll put the motor on an old garden tiller and buy a new and bigger pressure washer. You can always dial the pressure down, can't dial it up past a certain point. I have a 13 hp honda on a 3600 psi pump and sometimes I wish I had more pressure.
George
