Price on loadmaster Gooseneck
Ohio Case
Ok, to follow up on earlier thead, we concluded its around 14,000 lb capacity. Now to decide on what its worth. It will need totally redecked, (too many years outside), new tires, most likely new brakes and wiring, so basically i'm looking at a frame, it seems in good shape, the ramps are rough ( no surprise)I was thinking about $1000 to $1500 so am I way outa line, oh yeah it may not have a title either!
Lower is better always, but you're in the right range. I'd lean to the lower end, only because that decking, with bolts, will cost you more than the tires, and brakes and wiring will seem minor compared to either.
Don't know what you charge yourself for your time, but if you can keep your bottom line for trailer and parts close to $2000, I'd think you'll have done okay, as long as the frame is sound and you can get a title.
