Mad Farmer
- Location
- Northeast
Was hoping to get the Fergy running today. Carb/fuel system ready to go. Dist static timed
I pulled the plugs and gave each cyl a couple shots of oil, put a battery in and turned the engine ~30 seconds 8-9 times, giving the starter a rest in between. Spun over nicely with the plugs out.
I was concerned that the oil pressure gauge did not move. I was hoping to get oil to the top before starting.
I disconnected the oil line at the gauge and spun it a few more times, no oil at the gauge. Most likely gauge is OK. Put off trying to start it.
Is there an easy way to prime the oil pump? I'm assuming this is the problem. It has been sitting for well over a year/2 years.
A search here reveals pulling the fitting where the oil gauge line connects at the block, and using something like a gear oil bottle w/pointy tip to feed oil into the block.
If this is correct how much oil should you feed in to get the prime back? Will this be a PITA and take forever?
I'm open to other ideas to feed the oil into the block.
Thanks in advance
Thanks in advance
