mike clifford
Hello all. Has anyone done a fuel injection pump conversion on a john deere 202 engine? If so how did you overcome the throttle lever hiiting the engine, where the block gets wider under the exhaust manifold?
The only way i see is to tilt the pump away from the block and this messes up the timing. If this is the only way how do you line up the timing marks on the pump? Flywheel is TDC postion.
The pump i removed is a cbc 431AL and i am installing a JDB 431 2731. on a jd 450 crawler
As it is now the pump will not sit vertical with the throttle lever as is.
If anyone has seen this problem before or done a IP conversion on this engine please give me your comment.
All info and suggestions are welcome and appreciated.
Thank You
MC
Thank You
MC
