Herman, MN.
After posting here a month or two ago about a problem I was having, the consensus was a bad solenoid as I myself had suspected but wasn't sure how to double check, which I did and seems to be bad. I finally had sometime last night to replace it and it has the three post (same as the old one)and it I hooked the battery to the BATT side of the solenoid and also a smaller yellow wire that was with the old one and then the other end to the starter, and it started turning over, and I hadn't even hooked up the push button to the third post yet. Thinking maybe somehow it all had to be hooked up in order to eliminate that, I quick popped the cable off the battery so it would quit cranking and finished hooking up the tranny push button, problem persisted. Now I look at some wiring diagrams here and nothing I see show this other yellow wire. My question is, is there some purpose for this wire in a different wiring scheme or what's going on wrong here, because thats the way it was previously and always worked fine until it quit working, but now it just wants to crank on its own. Any help and suggestions are much appreciated, I did run off a copy of a wiring diagram here for a 6V system and will try and trace wires but thought maybe someone might have a quick answer to save me time, as it was about 15 degrees last night and the fingers get cold fast.
Joel
Joel
