Problem with YTC's Governor for 8N
gnswelch
This message is a reply to an archived post by Bruce VA on May 26, 2017 at 18:50:58.
The original subject was Re: Problem with YTCs Governor for 8N.
I wouldn't bother with a free I&T F04 ANYTHING, the one I paid for years ago called for a .025 Ignition point gap on a 51 8N! The Dwell on a 4 banger is around 60 degrees or double about what an 8 Cyl engine runs at, which is 30 Degrees.
That .010 oversight and plain huge 33% gap error will show up real good after you read dwell that in all likely hood won't even give a reading.
As for that governor...any luck yet?
Got a I-T manual for a Farmall 460 diesel printed in the early sixties. Their procedure for removing the harmonic balancer is a large bearing splitter in the pulley groove, and even larger two-legged puller to power it. Bad idea. After I broke the sheave, I found out later that the hub can be pulled on at its strongest point with a medium size three-leg puller, with legs pointing outward, hooked on flat spots between the spokes.
(quoted from post at 20:13:34 09/19/22) This message is a reply to an archived post by Bruce VA on May 26, 2017 at 18:50:58.
Since the correct breaker point gap for a 1951 8N IS 0.025'' I fail to understand your post???
(1951 serial number range is 343,593 to 442,034 and and the side-mount distributor along with it's 0.025'' point gap came along at # 263,844 in 1950.)
Also, point dwell is affected by distributor cam lobe profile, as well as number of cylinders AND point gap.
(quoted from post at 23:13:34 09/19/22) This message is a reply to an archived post by Bruce VA on May 26, 2017 at 18:50:58.
ou must pay attention to whether front or side mount distributors...gap is different. Your tractor being 51 should be side mount.
On front mount tractors,a gap of.015 is specified with a dwell of 35-38 degrees. The front mount is specified to be .025,but no dwell spec is given in the I&T.
