problems with 2N hydraulic lift
Tom in MS
Cannot raise and lower lift normally. PTO shaft rubs front of bush hog. Tried to adjust the lift lever on the right side to stop
the lift from going high enough to rub. I tried putting a stop on the hydraulic lift arm (lever on right side). If I set it where
the PTO won't rub, the bush hog barely clears the ground so basically the lift can't be adjusted. What do I do?
Limiter chains:
2N does not have position control. So the lift either is down or all the way up. So use limit chains like JMOR pictured.
(quoted from post at 12:00:31 10/11/21) Are limit chains going to keep it from going all the way up, rubbing the shaft in two again?
t does not raise when touch control lever is in down most position does it?
(quoted from post at 17:23:08 10/07/21) the lift can't be adjusted. What do I do?
Adding a position control device is an option.
No Tom. If you lift the quadrant lever all the way up, the lift arms will try and raise to the top.
(quoted from post at 10:00:31 10/11/21) Are limit chains going to keep it from going all the way up, rubbing the shaft in two again?
use the limiter chains on my 8n and never have a need to raise it but I can raise all the way without shaft hitting the mower. Do you have a long overrun clutch on it?
