Procedure for checking compression
Rkh
Got the landlord 2110 10hp running again and would like the procedure to check compression. Do you check with engine hot, air filter off, etc?
You'll get the highest number with engine warmed up, air filter off (mostly to see the throttle plate) and the carb wide open.
However, not sure that's a great diagnostic. I'd think you'd want the cold numbers, especially if you're having a starting problem. You still want the throttle plate wide open tho.
If this is the same tractor that had the carburetor issues, I am not sure a compression test will help. There is a good chance that engine has a compression release camshaft. I also have never seen a published compression chart for Briggs and Stratton.
I'm sure I read somewhere that you try to spin the flywheel by hand backwards. If there is a good rebound the compression is good. Watch your hand!
Other than that I have recorded 80-90 psi and the engines are healthy. kevin110
