stumpjumper400
What has the experience been with the proof meters and cables from this site? I bought the gauge kit for my 841 and a new metal cable. The meter worked for about 10 minutes of run time. When I removed the cable, the keyway spline that goes into the hydraulic pump was sheared off. I ordered another cable after checking the drive bolt and adapter shaft. They looked good with no wear. The new cable came in so I hooked it up and turned it with a drill. There was a noticeable hard spot in turning the cable. In trying to disassemble the cable from the meter, the cable is stuck in the meter.
Thoughts?
Thoughts?
