Proper tractor
ALWMach1
Hi,
We purchased a 15 acre mini-ranch (our future retirement home)in Texas and need a tractor for moving round bales and some minimal pasture work (moving feeders etc.). We have 12 of the 15 acres fenced in for cattle and goats. What would you recommend. I was told by some a ford 8N would be just right. But others have told me that they will not adequately move the round bails. Rookie needs help. Thanks
There are far better choices. 8N's were OK in their day, and they even have some use today. But they're note quite enough to be moving round bales. You'll find a few in decent shape, but consider their age and what "average condition" might entail.
For the price tag you'll see on the average 8N, I'd look around for a later model Massey Ferguson or Ford, possibly a MF150/165, 245/255, or a Ford 4000/4600. They'll set you back a few more pesos, but you'll have a LOT more tractor.
JMHO. but I'd look for diesel, power steering, live power, 3-point hitch of course, and in the 45 to 55 hp range.
I love the small Kubota 4wd diesels. Never, ever thought I would say it but I've spent a little time on one this winter and I now know what people have been talking about.
You will want something with power steering. The N series fords will not work adequately for moving round bales. If you do lift them you wont be able to steer it. Get more like a JD 3020,3000,4000 ford, IH 656 or somrthing like that. Wide front would be a plus and a mechanical front if your going to do a lot of loader work. On the west side of TX it is not as important as it would be on the east side due to moisture and soft ground during rains.
If you check the archives this topic comes up at least once a week.
Of course brand loyalty and what a person grew up with has a bearing on ones preference.
How much time do you want to spend in time and money "repairing"?
Round bales of what size?
What area of the country and what climate, soil type, previous experience etc?
Do you want warranty, simple diesel engines, hydrostatic trans so amateurs are going to smoke the clutch or break gears.12V alternator electrical systems, diff loc, M4WD, high volume/high pressure hydraulics with remotes. A real fixed drawbar, three point hitch and live pto. A rops,seat belt sealed beam lights for and aft, warning lights etc.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=ttalk&th=711376
I would agree that an 8N is NOT going to work on moving big round bales. If you find a loader you'll never be able to drive it (and the front end it pretty light for that kind of weight). You can't use a three point rear bale carrier because it will lift the front end off the ground.
Look at "later" (1960s and 1970s) model utilities with power steering like some those listed below.
Sounds like our place. 15 acres with about 12.5 of that fenced for horse pasture, 2 run in sheds, another shed for equipment storage, 5 stall barn, etc. I have a 9N here that belongs to my FIL and was kind of permanently loaned to me when we moved here. It works well for what it is, but most of the real work around here gets done by my Ford 3600 w/ FEL. Can find N's for $1500 up to $3500 around here depending on how proud the owner is of them. For not much more you could move up to a Ford 3000,4000 MF 150, 165, and certainly others with good parts availability. These tractors will work circles around the N's. I dropped most of $8000 for the 3600 ~3 years ago. As will be mentioned, Owning an old tractor means having some desire to turn a wrench once in a while (sometimes more often) or a friendly relationship with a mechanic. You will also find that it is often convenient to have more than one tractor. Around here the N get pushed into service most often when I don't feel like dropping an implement off of the 3600 so out comes the N. The N also spends a lot of time on spreader duty leaving the 3600 available for FEL work scraping out run in sheds. I have not been able to convince my wife that I need a tractor for every implement I own and another for a spare, but I keep working on it.
Good Luck on your search, try to determine everything you would want the tractor to do and then add about 20% since it is rarely said that anybody has too much tractor, but we often see an issue of trying to do too much with a small tractor.
Kirk
You will want live hydraulic, live pto,and power steering. Next, buy the brand that the nearest dealer sells as you will need parts and service from time to time. Nothing worse than driving a hundred miles to get a ten dollar part. Happy retirement. Joe
I have 160 acres and move round bales and mow and grade, dig holes, move stuff, etc... I have a Massey Harris 44 with a Du-Al loader.. that is my lifter ($2000) and a 1956 Farmall 400 ($2400) that does my pulling, mowing, grading, etc.. Both are gas engines but do have power steering. I have to say that is a MAJOR plus. So 1 that lifts and moves and 1 that pulls and plows. The Farmall has a 2 point fasthitch with a 3 point conversion on it and it can move round bales also... Personally I don't think a diesel is necessary for what you are looking to do. Gas is cheaper and parts/labor are also cheaper. I have diesel trucks and so I deal with both fuels. Keep it simple, since it is retirement living like me you aren't having to make a living at it so you don't (in my opinion) need to go for the real hardworkers. The big diesels and all are good when plowing and such, but it doesn't seem like you need to spend the extra money on the extra power. The loader is much more important for your application it sounds like. You will want to make proof positive that it is in good shape and will lift what you want before you buy it. You will also want to get both a bucket and a balefork. You can get clamp on forks but I haven't heard a lot of good things about them. So the ability to change loader implements also comes into play. Once you start playing with the tractor and loader you will find tons of stuff to do with it so don't skimp on that.
So, I guess I am saying that there is nothing wrong with old iron to do what you are needing. Maybe at a considerable coast savings as long as you make sure it is in good running order. I would get at least a 35 - 50 horse tractor if you are going to be playing with big bales. That size has the body and power heft to handle the bales safely. Also, there are different sizes of round bales. It sounds like you will be buying them. Bales can go from over 1200 pounds all the way down to 500 or so.. When in doubt, go for a bit bigger than you think you need.
Parts availabilty and a general mechanical ability are handy. Although you can get just about anything online these days.
And welcome to the site, regardless of what you go with you can get most any question that you have answered in a timely manner by people with years of experience. I have learned a ton. I would suggest taking someone along that knows something about tractors when you think you have decided on one.
- I agree with ultrdog's post except that there will be a LOT of mowing eventually. As a beginner myself, live PTO was really invaluable and safer. The ability to turn the mower on and off without the clutch or transmission saved my butt a couple times.
I agree the Ns are too small for round bales.
Whatever you get make darned sure it has FACTORY 3 point.
You can get by with a smaller tractor if you are willing to move round bales with a bale spear on the 3 point rather than a loader.
I like the 3 cyl Fords. Look at 2000,3000,2600,3600 models. 4000, 4600 would move rounds on a front loader but they are a little big for a lot of things.
Unless you are running a baler or snow blower I think Live PTO is entirely over rated. But I wouldn't be without PS and Live Hydraulics.
Three cyl Fords came both in gas or diesel. Both are excellent. Though around here the jury is still out on whether diesels STINK too much to be useful.
Lots of great help here. If you find one you're interested in post back with info and folks will help you not get took.
Pictures are always welcome.
No matter what you will find one tractor is not enough. Why because there are thngs one will do but the other will not and also if you only have one you will be hooking up and unhooking all the time which is a pain. Some thing like a Ford 801 series model 861 with a loader would do as your first but as I said one is never enough
Hobby farm
By the way I have 35 tractors and when its hay season I have 5 or 6 hooked up all doing different jobs. That way I can go out and do what needs to be done with out having to hook and unhook which takes time and is just plain a pain in the back sides
Ultradog I am glad to hear you say a live PTO is over rated. I agree. I currently have a 2020JD a 231S Massey and a Super H with non live PTO. While I do not have a baling issue my tiller is PTO and the bush hog is driven and I find no problem at all with using the SH. In fact I prefer it for sentimental reasons.
Personally if you want to run all those animals I would want more acreage. I have 37 and run about 8 to 12 cows and its not quite enough. Horses require a lot more land as they run and tear up the grass. You need to be able to move them pasture to pasture to let the grass come back.
As far as Tractor I have two L series Kubotas one a 77 two wheel drive 4 cylinder diesel that I use haying an such. But id worthless in the winter when its wet or muddy. The other is smaller 3 cylinder but wheel drive and will virtually go just about anyplace I have run it mud up to the engine and it just keeps going. Both will move the big bales but only on the 3 point and just barley. My friend makes some 800 lb bales for me that work great.
Walt
PS don't get the little Ford its just not enough tractor.
Look for a tractor that will handle a 6 foot mower or blade, something of at least 35 horsepower. When we bought ours I wanted a got live power and power steering. The N series of tractors were good for their times but lacked many of the things considered "basic" today. They are too light in the front end to handle rounds.
My personal favorites are the Ford 4000 series from the mid to late 1970s.
PS. Don't leave your tractor in the field with the goats because they will eat the wiuring and hoses and valve stems. At least that's what my goats did the first and only time I left the big blue Ford in the field.
'N's are nice to look at and that's about it.
They had their day. They replaced a team of horses... and time marched on.
If you're moving round bales, the smallest tractor that I'd consider to be safe in most conditions would be a 70's model Ford 4000 or something of similar size. That's assuming that the bales are smaller.
This is keeping in mind that you're new to tractors. You can get by with less, and many people have... but you don't have near the safety factor there.
Personally I'd want to move into somethign a lot newer like a Ford 3930 or 4630 that has FWD and a shuttle transmission. They are more money... but... you'd probably spend 3 grand for an 8N, 4-6 grand for a 4000 or something similar and then handy 10 grand for a 30 series Ford. Having done that you have a safe stable tractor that's well equipped to handle a large front end loader, good hydraulic capacity, good traction and still the same size as the 4000.
There are various other colors out there with similar models that will suit you. I simply speak of Ford's because that's what I run...
Rod
Now that you're thoroughly confused and after reading all the posts and based on you're acreage and carrying round bales probably the Ford Blue Line is best possibly the 4000 due to the fact you aren't sure of the round bale size and it has the ipto clutch probably the SU model low slung utility tractor so if you build a small outbuilding low door clearance won't be an issue better known as a straddle tractor with adjustable front end width.IMHO
If you ever want to mow or use a rototiller, you will want a live PTO. If you just have to move bales and not load or unload them on to a trailer or into a feeder, you could carry them on the 3 pt. An 8N is too light to be moving bales around but a newer 35 to 50 H.P. would work fine to carry them with the 3 pt. You might need to add some weight up front but that's pretty easy to do. If you don't need a loader, you can get by just fine without power steering. Diesel is worth paying a little extra for depending on the tractor. A Massey 35,50, 135,150,165,230,245 etc. would be a good choice. Perkins diesels in the 100 series and up are very economical to run and easy to start. Earlier Perkins like in the 35 are good engines but indirect injection so they're a little harder to start. Don't be afraid of a diesel but there are some to stay away from. The Standard diesel has a reputation of being a hard starter and pales in comparison to the Perkins. We used to have an 8N and it was a good tractor but traded it on a 135 diesel with a live PTO to run a mower. Big improvement but I think the 8N went through snow better. Dave
thanks again and you are right there has been a lot of info, but most of it is pretty consistant and has been very helpful. Thanks to all of you!
Al
Ditto horses. Only time you want to leave a diesel tractor in the field with them is if your tractor seat was looking a little shoddy, and you need an excuse to get a new one- they'll finish it off for you. With gas tractor, you get the added bonus of playing hide and seek for your spark plug wires.
