psb6a pump no high pressure
Hattrick
Just picked up a case 500. It has not run for 5+ years but always parked inside. We were able to prime the system and lift pump seems to be supplying fuel but there is no high pressure to the injectors. Looking inside the timing cover the pump seems to be clean as a whistle. My guess is that the plunger may be stuck.Is there any tricks to free it up? We have not yet pulled the hydraulic head as we thought that maybe just having fuel to the pump may help. I have only ever worked on an ih pump so do not know much about these. One thing i am wondering is whether the gear inside the timing cover should rotate or is that just to afjust the timing of the pump. Any help appreciated.
Most likely has a broken plunger, or at least the guide is broken that rotates the plunger. Best IT book that shows correctly how to remove/ replace the head is Oliver 66, 77, 88, 99 service manual..
In the Farmall MD the lift pump plunger will stick and you can sometimes free it up. I had to take mine apart. On the psb6a pump is it possible for the plunger just be stuck up if it stopped with the cam lobe up? Is the gear in the timing window supposed to rotate. Mine is not turning. If i take the hydraulic head off can it be replaced as an entire unit? Obviosly i would be able to see what is going on.
Most likely the plunger is broken and you will have fun finding a good head. Last Massey-Harris PSB I fixed told the owner bring any parts pumps you have, needed parts from 3 to make one work..
Hattrick,I have a American Bosh PSB-6A manual in a PDF file format that should help you out.Post a reply and your email address and I would be glad to help you out and send it to you.
Hattrick:Take the cover off that is above the transfer pump, it is right below the head on the side of the injection pump. There is a lever behind it with a rod attached that you should be able to move to the left and right. If it doesn't move it will need to be freed up. When the throttle is opened it moves one way and the other way when the throttle is closed. It controls the amount of fuel going into the head. Spray plenty of wd40 where it pivots and gently try to move it with a pair of plires. If the lever moves we'll go to the next step.
Hattrick: If the lever moves, I agree with dieseltech. The plunger was probably stuck and it twisted off #25 shaft in the pump. You will have to remove the injection pump and take the two screws off the cover on the bottom of the pump and the gear #28 and the broken shaft will fall out.
The rod linkage that you are referring to is free. It looks like the #28 gear is the one you can see in the timing window.it does not appear to rotate but was not sure that it was supposed to.i am still curious if the plunger could be just stuck in the up position or if that is not possible.
The gear you are referring to is the top gear of #25, and the bottom gear is where they twist off if the plunger is stuck. It is a mechanical connection to the pump plunger, and the weekest link, the bottom of shaft #25 will break. It has happened to me many years ago. The only way to prevent it is to remove the pump before cranking the motor and see if the input shaft of the pump will turn. It's a lot of extra work, but if it is stuck, it will usually free up with WD40, and working the shaft back and forth, just don't force it. Your quickest fix will be a used pump.
Untitled URL Link
Dieseltech; Some time ago I asked about my Deutz & its pump. I got a battery in it Turned it over a few times & got blackish grey smoke out the exaust. A sniff of ether & it was running normal again. The fuel is 4 years old. The color of the smoke is never white like unburned fuel, but it always need a sniff to get it going. Any ideas why?
Teddy, if you want to contact Dieseltech use the Private Message feature called “Conversations” In this case use his reply and hover over his profile avatar at the left of his reply. Then click “Start Conversation” the form is just like starting a thread but it is private between you and him. To start a Conversation outside of a thread click your envelope or letter icon at the top. Then click Start a Conversation, then start typing the members handle you want to contact in the Recipients box, when recognized it will pop up to select. The rest should be self explanatory. When someone replies to your PM or is initiating a new PM with you a number will show up by your “envelope” icon, click it to view them.
I'd try some FRESH fuel first..
When I got it ,it had been outside for 9 years & was tight. 1 cylinder was stuck & I had it apart & put new rings in that cylinder. Discarded old fuel & got fresh at that time. Had the pump checked out & got rebuilt injectors. Compression is the same on all 6. It always would put out dark smoke & would not fire without a sniff? Runs just fine once it fires up without any missing when 1st starting. It does put out a lot of smoke just sitting there running but I was told that is normal on thoe air cooled engines. I timed the pump according to some one who workes on them a lot. I had it advanced too much at 1st but it still always started hard. Starter was gone through also.
