sheared the pto adapter today for the second time, the one which slides over and pins onto the pto shaft on the tractor. i have been buying them from tsc. other than replacing the pto shaft with one the correct size, there is really no better way to do it, right? the first time i was bushhogging, didn't hit a stump or anything and all of a sudden the mower stopped, and the adapter had sheared. today, i was using the PHD and not long after it started digging, it sheared. the bit was not buried or on a root, i was able to pick it up out of the hole by hand immediately after. i can understand if i was hitting obstructions with the hog, or over-working the PHD, but are the adapters just inherently weak? maybe it's good that they break and not something vital!
as for the PHD, are there any "tricks" to lift it high enough to keep from dragging the bit? the horse collar has about ten holes for where it attaches to the shaft of the digger, but i couldn't tell much difference in any of the holes. the one in the middle seemed maybe just a tad higher. if not lift height, what are the different holes for?
