pheel
i have a super a farmall, someone put a slip clutch on it, how do i get it off, a big @#^*&! hammer thx pheel
There will be a small roll pin you have to remove with a hammer and a pin punch.May be behind the grease fitting or a small plug that will need to removed for access.Remove the pin and it will slide off the pto shaft.
If you ever pull a rotary cutter you will want to leave the OVER-RUNNING clutch in place. To remove you will need to remove both the pipe plug and the grease zerk. Line these two holes up with the toll pin and drive the pin out. Then remove the clutch.
Kent
