thelach
I have a 1948 8N. I pulled the PTO out to replace the seal. I looked on line to learn how . Igot the shaft out with the bearing. Then tookout the second retainer ring. There seems to be a small lip after the retainer before the seal. There is no way to slide the seal out. On the other side of the cover where the threads are for a spline cover, there's another round plate which seems to be part of the cover. I see that in no u-tube videos. What do I have? An original PTO cover that can't be fixed? I'm sending two pictures.
Thanks,
Jim
The cover screws into the part portrayed in the second photo. It looks like the hub covers on the front spindles.
You should be able to press out the old seal toward the bearing side of the cover. I did it with a piece of pipe and a small hammer. When replacing the seal the spring side of the new seal is towards the oil. I also found that installing a (third) snap ring between the new seal and the cover threads will protect the new seal from screwing the cover in to far. In the past I have also replaced a PTO assembly and ruined the brand new seal in the assembly by screwing the cover in too far. If you do replace with a new PTO assembly take one of the old snap rings from the old shaft assembly and install it between the seal and the threads to protect the seal!
JB
