(quoted from post at 03:07:39 09/17/23) Commonly available at Tractor Supply and other stores of the type.
Might find a direct fit, more likely will need to go the cut to length route.
Check YouTube for videos on how to cut and fit a PTO shaft.[/quot
Thanks for the help. I will check that out.
If you have the capabilities to do it your driveline can be repaired reasonably by welding a new shaft and tube to the yokes.
If you aren't able to do it yourself you may be able to find a reasonably-priced complete unit at the link below.
https://www.tractorpartsasap.com/search/?q=weasler
https://www.tractorpartsasap.com/weasler-ab4-series-pto-driveline-shaft-131243.html
Probably this one.
Those drivelines are designed to be cut to length.
(reply to post at 08:47:31 09/17/23) [/
Thanks for the great ideas. I will cut out the bent tube and square tube and add on new ends. Thanks guys for helping. I really didn t want to buy a new one. Take care.
