PTO for MF40 Industrial
You can use the PTO with an overrunning clutch. I use my 205 industrial with one to pull my tedder. Not a perfect setup but it works.
Hi Phill, I am looping back with your PTO setup for your 205 Industrial. How did you go about setting it up with the overrunning clutch?
His 205 likely already had a "transmission" PTO in it. Those use a single stage clutch, so when you push the clutch both the tractor and PTO stop. A heavy rotating PTO implement, like a brush cutter, can cause the PTO to transmit that power back into the transmission. That can cause a tractor to keep traveling even with the clutch disengaged from the engine. An over-running clutch used on the tractor's PTO shaft releases and lets the inertia of the implement spin the implement's PTO shaft but does not transmit that energy back into the transmission via the tractor's PTO shaft.
I have to guess that Phil's 205 already had a PTO shaft in the tractor, which he put the over running clutch onto. You posted you do not have a PTO in your tractor. Until you have a working PTO in the tractor, if you buy an over-running clutch, it will just be a shelf ornament, not the answer to what you are looking for.
Is it possible to add a PTO to my MF40? If so, what parts could I use?
