Nhpto
I have a New Holland TC30 and the pto light stays on even when the pto lever is disengaged. It wont start with the light on. This model doesnt have a switch under the fender. There are two screw in switches near where the linkage goes into the housing. Is one of these the rear pto switch? For two years the light would go out if I moved the handle back and forth but that no longer works. Are there any other reasons that would cause the light to stay on?
Hello PTO ha ha welcome to YT. The online parts books shows it as number 24 on its diagram. Unfortunately the neutral switch for the range transmission is shown at nearly the same position, however slightly forward of the PTO switch if the diagram is accurate in that way. In the link go to 06 Electrical, then 11A01 Wiring Harness. Clicking that actual opens the subsection preview boxes. On a phone I find the preview diagrams are clearer when expanded then inside the preview, find 24 sort of below the seat. Clicking that box will open the diagram and parts list. There is a part number separation for the switch, so find the correct one for your machine. Clicking the PN will price the parts for you. To determine which is which I would simply unplug the sender. Whichever one makes the light go out is the one. Not a 100 percent fool proof just depends how it is wired. They are certainly proud of them. I would web search the part number to see if a cheaper alternative is available. If not I hope yours is the lower priced one.
CNHI NH TC30 parts diagrams
Thanks. Ill check this out. I looked at a manual at the dealership that helped but wasnt very clear.
