PTO not disenengaging
nashranch
On my 69 Ford 4000 the PTO shaft turns all the time even with the PTO Knob pushed in(this is a Select o speed tranny so there is a knob on the dash) With the engine off I can turn the shaft ok with a little drag when disengaged. Is this normal ? Maybe there is an adjustment.
Maybe warped clutch discs?
Normal. There is no PTO clutch brake on your tractor. Now . . . if you attach a load to it and it still does this , , , get back to us.
(quoted from post at 09:36:32 12/01/18)
Thanks Larry
