pto problem ford 7000
kennyhatcher
This message is a reply to an archived post by kennyhatcher on July 02, 2016 at 13:06:36.
The original subject was "pto problem ford 7000".
hello
The pto works as long as duel power is on the low side so does anybody known if you take the cover plate on top of the transmission,
the plate that holds the gear shifter,the low side and high side shifter of the transmission. if you take that plate off, can you see the duel power clutch pack or the valve that controls the duel power.
You're wasting your time looking through the shift cover - nothing to see there related to the dual power. You have an internal leak on the high side of the dual power. Figure on splitting the tractor behind the engine and going completely through it. Also figure on a sleeve for the housing if it has the original metal seal rings.
