The pto speed is determined by the engine speed. 540 rpm is approximately 3/4 throttle, 1500 rpm. You mower does not have to operate at 540 rpm to work properly. The cutter is designed for speeds up to 540 rpm.
I should mention you need an over running clutch(ORC)on your pto for use with the rotary cutter. This limits transfering the rotary inertia of the cutter to the drive line when you disengage the clutch and thus elimates the implemment driving the tractor forward when you attempt to stop.
The tractor gearing is such that it develops its power at PTO speed and that is 3/4 throttle or 1500rpm, you should not run above this speed or you may damage your mower. Keep the blades sharp, don't cut too low, and make sure that they all weigh the same weight so that they will be in balance or the mower will vibrate and break up eventually. Keep the radiator clean and clear, wash it out from the engine side a couple of times a week at least, depends on how dusty it is, as all the air is sucked through the Radiator and any grass or dust often collects in the Radiator and the engine will run too hot. I have a leaflet about running a Bush-Hog on a Ferguson, if you would like it, just email me at:- [email protected]
it tells you the easy way to use it and what to do with the tractor to keep it cool...John
Jerry - does the need for an overrunning clutch PTO adaptor apply to belt-driven finish mowers? I can't imagine my Woods 600 mower shoving my TO-30 around once I get this thing back together.
In general yes.
Now I don't know the details of your finish mower, but if it doesn't have the large rotating mass that a rotary cutter has,(stump jumper plus large blades) it might not be as bad as the rotary cutters, but I'd play it safe and get one. You don't want to find out the hard way!
Another option is to get in a clear area with the tractor and mower, rev the tractor up so that you are at least at 1500 engine rpm and moving at mowing speed, step on the clutch and try to make an emergency stop. Repeat with the mower disengaged and note the difference. This will illustrate the magnitude of the problem for your specific situation.
Whatever you do, don't go mowing with your tractor until you have at least done the above check and verified that you can safely make an emergency stop. You don't want to find out the hard way that you can't make an emergency stop that keeps you from hitting the barn, running over an embankment, into a creek, over a loved one, etc.
