pto seal leaking
JV Texas
I replaced the pto seal and it held for about three months, then started leaking again. Is there something I'm not doing here? Should I have the shaft looked at? Any info would greatly help! thanks
Not sure what tractor you're working on but did you replace the bearings when you did the seal? If there is too much play in your bearings the shaft will wobble slightly and can destroy the seal.
you put the seal back in the same spot. if you'll look you'll see that there is a grove cut in the shaft. never put any seal back in the exact same spot. either buy one that is not as thick or thicker, but in your case here every body puts two seals in there now. you should be able to buy them from any good auto parts store.
(quoted from post at 03:44:26 09/02/08) I replaced the pto seal and it held for about three months, then started leaking again. Is there something I'm not doing here? Should I have the shaft looked at? Any info would greatly help! thanks
Did it be a OLD STOCK sealing? then it haves no long live time,
like you say after 3 months it leaks again?
TIP:
You can try to wind up the spring thats on the backside of the seal.
(only when the axle haves no longer the original size)
Good luck to keep the oil inside ;-)
8) Bauke
(sorry for my bad educated english when im wronge about the word "SPRING")
A quick check is to grab the shaft and see if you can move it up or down at all, There really shouldn't be any noticable side to side play in the shaft. If it does have a wobble to it that will take out a seal in no time flat.
