PTO seal replacement D15
Shawnba67
So I recently decided it was time to repack my lift arm ram. I ordered the parts the place said I needed. I pulled off the rear housing and thats when I noticed the supplied pto shaft seals go way up in there. What are the odds that I will regret not replacing them? How big a job is it to get to them? Does the tractor just split right there in front of the gear shift at that bolt joint? If I risk it and have to go back It doesnt look like I will have to re-remove the rear housing is that correct? I do not mind a little leaking, but my ram had a split in the oring and was using a couple qts per week. Thanks for any advice and good day
To replace those front PTO seals (2 of them) the tractor needs to be split in two at the instrument panel. I've done dozens of them over the years replacing the lift arm ram seals and hose and the rear PTO seal and Oring and nothing else.
