(quoted from post at 09:00:49 10/16/16) When you post you always need to say what tractor you have because pulling a PTO is not the same on them all.
Ya I know you have an 8N but these guys may not know that
Have you removed the shiftier cover like I said??
Are you trying to pull it with out taking the 4 bolts out of the PTO bearing plate?? If you are then you have already messed it up
(reply to post at 12:54:55 10/16/16) WOOHOO ITS OUT!!! LOTS OF PERSISTANCE AND MY 27YEAR OLD SON ON THE MUSCLES!
(quoted from post at 19:16:35 10/17/16) Concerning the lift cylinder ROD! Where it connects to the lift arm with the pin, how much play should be in the rod? Im talking about where the pin connects to the rod,should it be loose or tight??[/i]
(quoted from post at 16:08:39 10/19/16) WHAT ABOUT THE CAM FOLLOW PIN??SHOULD IT BE PERFECTLY ROUND OR IS A FLAT SIDE TOWARD THE LIFT ARM OK?? THANKS FOR THE HELP YOU GUYS ARE ALL AMAZING :lol: :lol: :lol:
