JohnnyHville
Regarding a 1946 2N.
Tired of messing around with leaky old pto that requires an adapter to run anything. I want to change over to newer 1 3/8 style.
Is this really as easy as:
park front end on a steep downhill,
remove four bolts,
slide out shaft,
clean off old gasket,
put new gasket on,
slide in new shaft,
re-install four bolts?
Any issues I should be on the look for?
I don't suppose there is such thing as a replacement shaft with a ORC built into the bearing housing?
BTW, last spring I honed out the lift cylinder and replaced the seal, inspected the pump, cleaned everything real good. Lift and pto works great. Will hold an elephant 3 ft off the ground overnight. Other than leaking and being incompatible with all my equipment.
I love the simplicity of this tractor. This machine is great for teaching kids the basics of mechanics and internal combustion engines.
remove four bolts,
slide out shaft,
put new gasket on,
slide in new shaft,
