What size is the pto shaft on a 1951 8-n.i picked up a bush hog at an auction. the seller had it on a small john deere. the shaft receiver was to big for my shaft so i picked up a sleeve at tractor supply. :( it did not stand up to the stress test. the receiver on the bush hog telescopes to the point of being 2 pieces. is it possible to get an end that will fit on my 8-n that would slide onto the shaft, that telescopes, of the bush hog.
You will want an over-ride clutch with using a brush mower. If not the spinning blade will force your tractor forward and you will run yourself into a fence, ditch, pond, or whatever....
If you are saying that the shaft on the mower is too short, you may have to replace it. Using an ORC which comes in various spline sizes may fix your problem and you need the ORC anyway.
hey Danny......they are "cheap" when compared to running into the side of yer wifes car (don't ask) .......Dell, the ORC Safety Preacher
