Curtsat15
Hi guys. I have what may seem like a bit of a silly question. My 2N book says I have 1 3/8" PTO shaft. My Power Major's book says I have 1 3/8" PTO shaft. I KNOW the one for the N is correct, but the drive shaft off the finish mower does not fit the Major, it's too small. Does anyone know what the actual size is for the PTO shaft on the Power Major?
There were 3 sizes of pto. First was the 1 1/8" size used on most tractors untill the mid 50s. Your N would originally have had that size but could have been converted.
Next came the 1 3/8" size. This is probably the most common size ever made.
Lastly came the 1000 rpm size which is bigger in diameter and has completely different splines.
The reason pto shafts got larger and then went to 1000 rpms is it was not possible to put the ever increasing horsepower of tractors through the smaller shafts. IIRC about the limit that can be pushed through a 1 3/8" shaft is around 85 hp. The 1000 rpm shaft is close to 2" in dia and will accomodate over 200 hp.
Some tractors had twin pto shafts - 540/1000. Some were convertable. I don't think any of the Majors - including Power and Super Majors - had anything other than 1 3/8" shafts.
my 42 2n had 25 hp. odds are the shaft was a 1 1/8". laying on the bench when i bought the farm was a machined converter. looks like it was common to shim them up for modern hogs etc... is that still common practice?
just curious, what is the biggest hog an old 2n can handle with a 1 1/8" shaft? wonder what the rpm's would be? any idea?
Question for Ultradog MN:
In your post you used the term "IIRC" - I have seen this used before however I can not figure out what it stands for. Could you enlighten me.
Thanks.
[i:654c4848f0]"My 2N book says I have 1 3/8" PTO shaft"[/i:654c4848f0]
OK let's start over. Which book?
Your 2N came originally with a 1 1/8" pto. If the mower is not fitting on your Major you can buy an adapter to convert it.
Any place like Fleet Farm Or Tractor Supply will sell them.
LOL, that's alright, I just recently learned that there were 2 sizes as well!
I was familiar with the 1-3/8" shaft, but was unaware of the larger shaft!
I could be wrong, but IIRC it's 1-3/4" 21 spline.
We don't got too many high HP trators, that would need it, around here!
As for the Power Major, I would be very surprised if it had anything other than a 1-3/8" 6 spline shaft. I would be inclined to look for some other issue, like the possibility that the finish mower has a 1-1/8" end, or that there is a conversion sleeve in the mower end? Possibly even something as simple as rust buildup on the Major's shaft?
JMHO, HTH, Davve
The 9N, 2N and 8N came with a 1-1/8 inch PTO shaft which is smaller hen the now standard 1-3/8 size shaft. There is a replacement PTO shaft for the N series which will bring it up to the standard size shaft or you can use an ORC which is a good idea to do any how
Dealt with a lot of PTO size issues this spring myself.
As others have said...the original pto was 1 1/8 6 spline. You can pull the entire shaft and go up to 1 3/8 pretty cheaply and easily. You an get the replacement shaft right here. It is a direct replacement and bolts right up.
What I did was put a 1 1/8 female to 1 3/8 male over run coupler (ORC) from Fleet Farm for $48 and about 10 seconds of time to get it on.
So far this combo has been running like a champ, cheap to implement and takes little time to install.
I use the reducer very much like the one shown.Be prepared if you mow some wooded or wet areas, as i have split a few.But at $7.00ea. a cheap fix compared to what i could have broken.Also a great present if you are hard to buy for.
