PTO spline came off
jbull380
The PTO spline came off of my dads 8N. I found a broken sleeve or pin or something that I believe is whats left of whatever secures the external spline to the spline shaft. What do I need to do to fix this?
If your 8N still has the original 1 1/8 spline PTO shaft, and the over running coupler is 1 3/8 spline, there was an adapter sleeve. That would be what shattered.
(quoted from post at 12:58:30 10/16/21) The PTO spline came off of my dads 8N. I found a broken sleeve or pin or something that I believe is whats left of whatever secures the external spline to the spline shaft. What do I need to do to fix this?
oll pin (lower right) length is critical, so as to allow outer & inner parts to not be connected together with the pin)
Good morning, mine did the same thing recently.
There were/are two different PTO shafts available. The original had a 1 1/8 six spline output, and
the later had a 1 3/8 six spline output. Correspondingly, there were two over run couplers (ORC)
available with the female splines to match.
Mine had the smaller, 1 1/8 splines.
If that is your setup, what you need is a 5/16 X 2 (8MM X 50MM) roll pin. DO NOT install a longer
pin! (The good folks at our local tractor store sold me a 2 1/2 pin. If I had installed it, both
sections would have been locked together and the important OVER RUN feature would have been
defeated!
IMPORTANT!!! IF you have a 1 3/8 shaft, you will need a somewhat longer pin. (Sorry, I do NOT know
that dimension.)
In either case, when installing, it is IMPORTANT to be sure that the pin is CENTERED (this may take
some careful tapping back and forth), making sure that the clutch drives in one direction and
ratchets freely in the other.
