Jim.ME
- Location
- central ME
I am guessing it is not a 1000 rpm PTO spline on that old gearbox. It is more likely just the spline count and shaft diameter the manufacturer of the gearbox chose to use. You might have some luck if you can identify the cutter and the gearbox on it.Thanks everyone for your replies. In answer to "used red" and "caterpillar guy" I understand that using an adapter is not ideal and utilizing an ORC would be preferable, but I apparently have no other options. Agri Supply does not have a complete drive shaft that will fit my situation...I checked with them along with Tractor Supply, Race Brothers, YT, Ebay, Craigslist and others and spent hours online searching for a solution while also asking on this forum. My driveline needs to have a 1 3/8" 6 spline yoke on one end and 1 3/8" 21 spline yoke on the other end and the distance between the tractor PTO shaft and the bush hog shaft is 35" measuring from the back of the shafts. I could not find this configuration on a complete driveline anywhere and I spent many hours searching. As a matter of fact I could not find a 6 spline to 21 spline anywhere no matter what length. "Farmalldude45 may be right...my very old bush hog maybe was designed for a 1000 PTO rather than a 540. However, it worked fine with my previous Allis Chalmers D17 and also with the Farmall H before I lost the driveline.
You could try contacting DN Equipment, their phone info is on their website. The deal with a lot of different aftermarket implement parts and drive lines.
