Wasgd4u
SHOULD PTO SHAFT BE TURNING WHEN BOX SCRAPER IS IN DOWN POSITION AND TRACTOR IS MOVING,LIKE DRAGGING A LOT?ON A 49 8N.NOVICE HERE
The PTO needs to be turning any time the 3-point lift is needed, as the PTO shaft passes through the hydraulic pump and drives it.
There is supposed to be a cover over the PTO when not in use, to keep you from getting entangled in it.
You might also check the parts section here and pick up an owners manual for that tractor. not very expensive, and has tons of good info explainin tractor use and operation, and maintenance..e tc.
soundguy
