coryeneks
ok im back again i have a 48 8in red belly i am trying to bushhog and my pto lift will run right for a few min.and it will either raise all the way or fall all the way down and i never will move my pto lever can someone tell me what to do to make it run the way i want it to????thanks
Well #1 it is not the PTO lever you need to move to have the lift work it is the 3 point lever. #2 haven't you asked this a few other times?? # 3 if you haven't then you need to make sure you have the draft/position control lever in position not draft mode. Position mode is with the lever up. If you do not know which lever that is you need to buy the FO-4 manual and start reading what is what
pto = spinning shaft on the back of the tractor, with it's own lever.
3pt = 2 arms on the back of the tractor that lifts & lowers an implement you have atached, with it's own lever.
So, now, what the heck are you talking about? Are you having a problem with your 3pt, or your pto?
And - this question does sound familiar to me too....
--->Paul
