Pulley alignment on wood chipper
37chief
Location
California
My chipper uses a drive belt with 6 belts ganged together. pulley shafts are 4 ft. on center. The motor pulley is 8 inch,chipper pulley is 11 inch. I installed a new belt, and used a straight edge on the pulley surfaces. The motor pulley is 3/8 out of alignment with the chipper pulley. Is 3/8 of a inch really going to make a difference? I can move one of the pulleys, but sometimes it's best to let a sleeping dog lay. Stan
Yes 3/8 is a lot on belt alignment especially with the cost of married belts. Get er ligned up and you'll be a lot happier
Why are you replacing belt? Is it possible that the misalignment caused premature wear? I WOULD go to the trouble of aligning as true as possible because just a small amount will wear belts and As you know, they are expensive!
Your new belt will be shorter than the remaining 5 belts which have stretched, 5 belts should pull the chipper just fine. The new belt will be pulling the rest out of alignment, or buy 5 more matched belts.
I'd align the pulleys as good as you can, then just run it. No use adding a new unmatched belt, it will just carry an unproportional load and break. If five properly aligned belts will carry the load you will be fine, for a while at least. Most drives have a significant safety factor so it may be OK for a long time. If you finally have to replace the belts consider going to a "grip-band" style, which has worked very well for me in multiple belt applications.
i am reading this as you replacing the whole gang of 6 belts, not one individual belt as that definitly wont be the answer as it will be shorter. 3/8" in 4 ft is not all that bad but if possible closer to zero is better. belts are made to run in all kinds of position. how long did the original last? i would be more concerned about pulley wear than that 3/8" . if the belt is riding to low in the pulley grooves then you will damage the new belt. running belts too loose cause slippage and pulley wear.
Shafts four feet on center is pretty close and 3/8 of an inch is a lot. I would take the time to move the one pulley over.
We would change belts on a 350 horse electric motor driving a blower that had shafts maybe ten feet apart and would use a string to get the pulleys in line. It takes a little time but is worth it.
