pappa
what spindle pulleys from differant mower decks
will interchange with my case mowing deck.
my belt gets cut up and wont stay on
well the pulleys are at fault because the 1 on
my desk has only 1/2 the bottom side and what is left is knife thin and jagged.
OK... good used pulleys from sellers such as Joe's Outdoor Power show up on e-Bay all the time. I suggest that you stick with OEM pulleys so that the offset is correct. If you get the offset wrong, then belt alignment becomes and issue and rapid belt wear will result.
Do an e-Bay search under "case lawn mowers".
