Pulling injection pump
Bret4207
Case 530 diesel. Pretty sure I know the answer, but when it warms up a little I have to pull the pump to send it out for service. Logic says I should get the engine at TDC by the marks before pulling it. I can't think of any reason why not to do this, but I don't know if that's "the correct way" or not?
It has to have #1 cylinder TDC.
Removal requires a special procedure that is to lengthy to explain here.
You need the service manual. The 580CK has the same 188 diesel in it. A service manual for the 580CK will be almost identical to the 530.
Here is one of the pages showing the procedure.
That pump is NOT to have the timing marks aligned at TDC. Look on the valve cover, Case engines usually have the timing spec and valve settings decal on the cover. If I
recall the 188 pump timing marks should align at 6 or 8 degrees BTDC.
The pump gear cover does not need to come off for pump remove/replace, UNLESS the pump shaft needs replaced. Pump can be removed from rear leaving shaft in engine after filter/bracket and lines removed. He will also need a 9/16 open wrench, I welded a wrench with the open end at 90 degrees for the back lower stud nut that's hard to get to. Some JD and Oliver/Waukesha engines need the same wrench, whenever three pump mounting studs are used.
I fully agree that the shaft does not need to be removed.
I just randomly copied that page to demonstrate what the service manual covers.
If the OP has never done a pump R&R he really needs the service manual.
The OP, me, isn't doing the repair, I'm sending it out to Dieseltech.
Dieseltech- I remember seeing the marks you're talking about in a video. I'll follow that advice, thanks!
